Mechmate using Pultrusion Material (FRP)
Itīs possible or anybody build the MM with this material?:
Pultrusion Process: https://youtu.be/1sH9rIGWNvc The main material is fiberglass. |
The video gives no real information on the material properties. I suspect the rigidity would be poor for a large table. However I suspect the main issue would be price. It is probably cheaper to use steel.
FRP vs Steel https://youtu.be/usjxvc7w7bM https://youtu.be/OIHwGP85R1o https://youtu.be/uUOyxfrs-EM Long live the diversity! |
Hi, none of those videos add much in the way of information. If you feel confident it can do the job and you can find profiles available that you can substitute into the plans then give it a go and post your findings here.
https://protector.com.au/q-the-match...mers-vs-steel/ |
| B15 Marine Fire Resistant Material | Andrew_standen | Cutting various materials - bit selection, feeds, speeds | 5 | Fri 23 June 2017 04:38 |
| Laser Cutting Thin Material and Etching on a MM? | domino11 | 50. Toolheads | 2 | Tue 03 June 2014 18:01 |
| Micarta, Alternate Material Source | Mrayhursh | Construction started, but not cutting yet | 15 | Tue 19 November 2013 03:55 |
| Which Material is best for a Front Door | Maylinda | Miscellaneous / General / Whatever / Catchall | 1 | Tue 13 July 2010 11:45 |
| Looking for material list | extremecanvas | General - MM Build | 4 | Wed 25 March 2009 23:37 |
