Old Mon 25 January 2010, 07:34
blakekoehn
Just call me: Blake #47
Macon, MS
What springs to buy?
I must be missing it because I have searched the forum several times... What size springs do I need to hold the motors up and where is a good place to order?
Old Mon 25 January 2010, 07:50
I think this is what I had ordered from www.mcmaster.com
9654K324 for the tension springs. Double check it to be sure though.
Old Mon 25 January 2010, 08:07
M310100K Springs for loading motors against the racks
Old Mon 25 January 2010, 21:37
Blake I used the springs from self closing flap hinges that one uses on your kitchen doors,does the job.
Old Mon 25 January 2010, 21:49
I used springs that keep the RADOME cover of a microwave dish in place.
Old Sat 22 October 2011, 17:54
IN-WondeR
Just call me: Kim
Randers
Denmark
Has anyone ever thought of using a gas spring for the motor spring?
Old Sat 22 October 2011, 23:41
Old Sun 23 October 2011, 00:56
Or a blade spring, or a rubber spring, or a polymer spring, or many other types of spring . . . . . .
We have a very small movement distance and rubber/polymer should be the simplest cheapest.
Old Sun 23 October 2011, 01:17
it can even work without a spring if you can orientate your motor & other weighty stuff to generate enough counter-reaction force/moment.
Edit. but I'm a simpleton miser... Spring works.
Old Sun 23 October 2011, 17:49
Red_boards
Just call me: Red #91
You have seen the spring details in the plans, right?
A spring maker will have no problem producing these if you can't find similar off the shelf.
Old Sun 23 October 2011, 20:47
These things also do the job - has been proved by more than one MM builder who are all too shy to show their pics
Old Sun 23 October 2011, 22:28
SERIOUS!!!! Cable tie!!!
Old Mon 24 October 2011, 02:30
IN-WondeR
Just call me: Kim
Randers
Denmark
It was only a question, I have built more than one machine now, and I'm planning a new build once again.
Offcourse I have seen the plans, I have had them all since 2007 and every revision released since.
I was just wondering if anyone actually had used something like those before..
Old Mon 24 October 2011, 11:07
...Okay, I'll confess, I used rubber bands for about a week or two until I got my springs in. It worked just fine!
Old Mon 24 October 2011, 15:21
Doesn't a gas spring only push, or are they available in pull type? If only "push" is available then the motor mount will have to be re-engineered...
Old Mon 24 October 2011, 23:27
Ok, Gerald you probably saw me using them I used some on my machine and still have a couple next to the machine,I hooked the z-axis motor on with some and the ( can`t remember the part but the one with the bearing that runs on the y-car.).I couldn`t find springs in my valley so I used the ones you get on the self closing flap hinge that you use in your kitchen.Had no problems yet.
Old Tue 25 October 2011, 03:02
Wonder when some one will tie some balloon as make-shift Z gas-spring....
Old Tue 25 October 2011, 04:13
Tried that already Ken, doesnt work so well as the balloon keeps losing helium and it intefered with my dust extraction pipe...
Old Wed 26 October 2011, 23:03
Lmao!!!!
Long Z axis and motor springs glintid 40. Z-Slide 5 Thu 16 January 2014 09:32
Before I buy could you guys please check my purchase Regnar 702. Power Supplies 2 Mon 18 January 2010 21:31
Hello from Palm Springs DrReaper Introduce yourself and start planning 1 Fri 18 December 2009 05:55
considering to buy a diy kit 1leonchen Archives 1 Tue 23 June 2009 20:56
to build or to buy? greginwa Archives 11 Wed 23 January 2008 08:22
