Old Sun 23 May 2021, 23:52
slobato
Just call me: Leandro
Lauro de Freitas
Brazil
Mechmate using Pultrusion Material (FRP)
Itīs possible or anybody build the MM with this material?:
Pultrusion Process:
https://youtu.be/1sH9rIGWNvc
The main material is fiberglass.
Old Tue 25 May 2021, 04:02
sphericos
Just call me: David
Suffolk
The video gives no real information on the material properties. I suspect the rigidity would be poor for a large table. However I suspect the main issue would be price. It is probably cheaper to use steel.
Old Wed 26 May 2021, 06:46
slobato
Lauro de Freitas
Brazil
Talking FRP vs Steel
Others comparatives:
FRP vs Steel
https://youtu.be/usjxvc7w7bM
https://youtu.be/OIHwGP85R1o
https://youtu.be/uUOyxfrs-EM
Long live the diversity!
Old Wed 26 May 2021, 07:34
sphericos
Just call me: David
Suffolk
Hi, none of those videos add much in the way of information. If you feel confident it can do the job and you can find profiles available that you can substitute into the plans then give it a go and post your findings here.
Old Wed 26 May 2021, 09:52
slobato
Lauro de Freitas
Brazil
This article responses your questions? I wait that yes.
https://protector.com.au/q-the-match...mers-vs-steel/
B15 Marine Fire Resistant Material Andrew_standen Cutting various materials - bit selection, feeds, speeds 5 Fri 23 June 2017 04:38
Laser Cutting Thin Material and Etching on a MM? domino11 50. Toolheads 2 Tue 03 June 2014 18:01
Micarta, Alternate Material Source Mrayhursh Construction started, but not cutting yet 15 Tue 19 November 2013 03:55
Which Material is best for a Front Door Maylinda Miscellaneous / General / Whatever / Catchall 1 Tue 13 July 2010 11:45
Looking for material list extremecanvas General - MM Build 4 Wed 25 March 2009 23:37
