Old Sun 19 September 2010, 00:52
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
Sounds weird, but looks like i got bad set of bits. Yesterday arrived second shipment and i cutted with one bit 6 sheets of alu. That is 12 hours cutting.
Old Tue 05 October 2010, 16:22
ifffff
Parnu
Estonia
And final truth of cutting alu 5754 sheets is totally different as discussed before... I moved from 4mm bits to 5mm bits because they are stronger and dont broke so easy and give better results.
Final cutting data:
5mm one flute endmill (20 degrees spiral angle)
Spindle 20000 rpm
Ramping plunge (10 deg ramp angle 10mm ramp lenght) feedrate 1500mm/min
Cutting feedrate 2000mm/min
I was cutting 4mm sheets and cutting depht inside contures 2mm per pass and outside contures 1,33 mm per pass. Outside i was cutting less with one pass because sheets arent always ideally straight and if cutter takes more than 2mm it goes to resonance and it may broke.
Some pictures too:
Old Tue 05 October 2010, 19:06
Expertly done.
Looks like racing car seat backs.....nice!
Old Tue 05 October 2010, 21:54
Regnar
Just call me: Russell #69
Mobile, Alabama
Nicely done. How many bits did you end up going through. Are they going to be bent. The reason I ask is the grain direction looks different across the different pieces.
Old Wed 06 October 2010, 02:45
ifffff
Parnu
Estonia
They arent rally car seat backs. they are ATV skid plates. I make cutting job and then they gonna be bent and welded.
Old Thu 25 August 2011, 15:34
ifffff
Parnu
Estonia
Some pictures of one job. Wind turbine blades, 2,8 meters long. Workpiece was 120*400*3000 mm. Cutting time for one blade about 16 hours.
Pictures:
Old Thu 25 August 2011, 18:59
exceptional use of the MM. Bravo.
Old Thu 25 August 2011, 21:12
Sweet !!! Have I mentioned how awesome MechMates and their owners are ?? !!! I am loving all these great projects I am seeing everyone working on.
Old Fri 26 August 2011, 05:09
Is that blade made from a single block of lumber or is it laminated.
You can't find lumber that is that nice for a good price here in the states.
Old Fri 26 August 2011, 07:43
ifffff
Parnu
Estonia
Its laminated spruce. Price here is about 100€ per piece. Many are already asked for sharing blade file. I post it here. Profile is NACA 4419
Old Fri 26 August 2011, 09:02
Those blades look like they can be quite heavy?
Old Sat 27 August 2011, 16:20
ifffff
Parnu
Estonia
No they arent so heavy. One blade weight is about 15-20 kg.
Old Tue 23 August 2016, 10:22
ifffff
Parnu
Estonia
Havent posted here for long time. I decided to build second mechmate. This time all steel tubes. Work area same as first one 3400x2100
For now steel is here.
Old Fri 26 August 2016, 03:35
Good luck with the second build Ivo.
Do you have that turbine blade in STL format.
I tried some online conversions but I keep getting a empty file message.
Old Fri 26 August 2016, 07:26
ifffff
Parnu
Estonia
I have .igs file. Stl seems to be already deleted. If that format is ok give me your e-mail address.
Old Fri 26 August 2016, 07:53
I downloaded the .igs file from your earlier post.
That is the one I tried to convert to .stl online.
Thank you for your reply.
Have a good weekend.
Old Sat 27 August 2016, 01:06
ifffff
Parnu
Estonia
Here is stl file. tiivik.rar
Old Sat 27 August 2016, 04:01
Smile
Thank you very much.
It worked.
I will build one to scale some day
Old Thu 08 September 2016, 03:14
ifffff
Parnu
Estonia
Its taking shape. Has someone good idea how should i turn this beast on feet? If i gonna weld base table all togehter i weights about 900kg.
Some pictures too:
Old Thu 08 September 2016, 21:27
Borko
Just call me: Techstarve
Veles
Macedonia
Good luck with second build Ivo.
Old Fri 09 September 2016, 09:26
ifffff
Parnu
Estonia
Its now on feet, with help of telescopic loader. For cross bearers i added one rectangular tube to support center. With 115kg load ( i standed on it) bends cross bearer 0,08mm. On my first mechmate i havent measured bending, but it is visible if i stand on table.
Old Fri 09 September 2016, 13:21
Nice and beefy ;-) good to see some activity here.
Why did you make your triangulation short as in with straight pieces in between ? You loose a little of the effect yoir are after that way.
Also since you are all welded, other way round would mean even more stiff tabletop.
Old Sat 10 September 2016, 00:19
ifffff
Parnu
Estonia
Making triangulation is limited by bandsaw sawing edge. But i think its strong enough like this. Diagonals and lower cross braces are made from 80*60*4 rectangular tube, cross bearers 120*60*5 tube. By adding 5x more steel i think table is almost unbendable, but this is already story of third build.
Old Sat 10 September 2016, 02:54
ifffff
Parnu
Estonia
More about rigidity. Main beams are 200*100*8 tube, end plates not welded yet. I fixed indicator on cross bearer and its needle to upper edge on main beam. Flex with twisting it with hands are 0,02mm. #38 main beams are made from 200*75 C channels and i can twist them about 1,5mm!!!!!!
Old Fri 16 September 2016, 06:49
ifffff
Parnu
Estonia
To achieve better accuracy i gonna use hiwin HGR20 linear guideways. To get linear slides better fixed and keep them on their place i made from 12*80 steel bar linear slide bases. Of course i milled them out with mechmate.
Milling with endmill tip is good endmill killer.
For saving bits as cutting 2,5*20 stripe on steel bar i drilled some holes.
Steel bars were quite warped too, so lets cut them straight.
Milling steel bar
On video i am cutting steel bar straight with endmill side. Spindle 10000rpm, feedrate 480mm/min, stepover 0,6mm. Endmill is TaeguTec TSE 2060M UF10
Old Mon 19 September 2016, 02:19
That's cool ! Interested to see the linears, I have same laying around, but never mounted them yet still using MM v rails.
Old Tue 20 September 2016, 00:47
ifffff
Parnu
Estonia
To make main beams straight i am levelling them with epoxy.
Dams made from melamine board and coated with mold release wax are in place:
To seal it correctly i poured first on corners one layer fast curing epoxy:
Old Wed 21 September 2016, 04:46
ifffff
Parnu
Estonia
Meanwhile when epoxy is curing i have lots of holes to thread. For rails about 230 pieces.
Old Thu 22 September 2016, 00:29
ifffff
Parnu
Estonia
Laying epoxy went out good. Nice and flat surface.
Old Mon 07 August 2017, 04:47
ifffff
Parnu
Estonia
Here are some updates about buildlog over looong time.
Linear rail straightness is checked with steel wire. Hanging weight on one side is about 35kg
Linear rail block mounts milled
To make it more stiffer as original Mechmate, gantry tubes are 120*60*5
Stair Beam Machine !!! #120 - Jõgeva Estonia ilmataat MechMates already cutting 48 Tue 21 June 2016 15:28
MechMates in NE or Central Florida, Jacksonville, FL Metalsmith General - MM Build 15 Mon 28 December 2015 09:18
MechMates wanted in Saudi Arabia Nicolas The Market Place 2 Tue 13 December 2011 05:13
Hi from Estonia! v2ikekresu Introduce yourself and start planning 10 Fri 26 August 2011 10:05
Completed Mechmates Album With Serial Nos. vishnu Archives 3 Sat 25 October 2008 12:53
