Old Wed 24 February 2016, 14:49
Mineral spirits are slightly greasy themselves..better using alcohol or thinner.
Old Wed 24 February 2016, 16:17
Kornerking
Just call me: Pete #127
Big Falls, Mn
Thanks for the input Fox. Wood I know just what to do, metal not so much.
Old Thu 25 February 2016, 12:31
Kornerking
Big Falls, Mn
Our paint arrived today.
Old Thu 25 February 2016, 14:21
Better get your camera checked, that blue looks gold??!!
Old Thu 25 February 2016, 17:49
Kornerking
Big Falls, Mn
Ya, I know.
But it is a blue gold.
Company colors.
Old Thu 25 February 2016, 18:24
MarkRH
Just call me: Mark
Maryland
Would be interesting to use a wood graining kit over that color
Old Thu 25 February 2016, 19:19
Kornerking
Big Falls, Mn
I pondered that Mark.
Wasn't sure how to accomplish it though.
Old Fri 26 February 2016, 08:29
Kornerking
Big Falls, Mn
Z slide grind
I set up a radial arm saw with a grinding disk to cut the z slide. Worked pretty slick. It took about 35 minutes to grind it out.
Short video. https://www.youtube.com/watch?v=zbrBcUd9pvc
Old Sat 27 February 2016, 11:51
Kornerking
Big Falls, Mn
Painting day
Got the beast into the spray booth and primed and painted. It went pretty well having it suspended.
Only 2 issues. I didn't order enough for everything. Probably won't have it for 3 days.
The paint has a metallic flec to it and it plugs the tip on my Kremlin gun. Frustrating.
At least I can get the big piece out of the booth. It goes in on it's side so I don't want to do it twice.
Old Sun 28 February 2016, 00:04
Rock-n-Roll!
Old Mon 29 February 2016, 05:16
Cool on the Z grind!! I think that method is a first. What grit was that wheel and what kind of saw is that?
Old Mon 29 February 2016, 05:49
Kornerking
Big Falls, Mn
That is an old radial arm saw with a tilting arbor. Sears Craftsman brand.
I set a fence to slide against, at a slight angle to the grinding disc, so the leading edge cut. The cutter is just a 4 1/2 grinding wheel.
Need still pics?
Old Mon 29 February 2016, 06:55
Kornerking
Big Falls, Mn
Back on it's feet.
Well we needed to get the beast back on it's 4 legs. It came out of the spray booth on it's side. Tony refused to climb the ladder and install a sky hook in our 20 ft high ceiling. ( Sheez, kids now days)
So after a little head scratching we put a plank across a doorway and used come alongs and a floor jack to gently lower it down.
Old Mon 29 February 2016, 15:36
Kornerking
Big Falls, Mn
Talking
Our steel company is offering 29% off all orders today. http://campaign.r20.constantcontact....2-d4ae527536ce
I should order for a second machine. I did order for a different application. We are installing a loader and unloader above the Mechmate so I ordered up for the gantry for it, and new forks for my skid steer. Oh, and steel for my new sander.
Old Mon 29 February 2016, 19:13
I'll be following your loader/unloader progress with interest.
Old Mon 29 February 2016, 19:50
Kornerking
Big Falls, Mn
It will have it's own vacuum motor to pick the plywood up. Hopefully enough suction to pick the processed parts up as well.
Old Tue 01 March 2016, 04:56
Nikonauts
Just call me: Nikonauts
Johore
Intriguing ... Keep the updates coming!
Old Tue 01 March 2016, 06:43
Kornerking
Big Falls, Mn
With the vacuum motor, winch, trolleys and steel I will have about a grand into it.
But it will make it so anyone can load and unload the machine. Even an old Fart like me.
Old Tue 01 March 2016, 16:58
I've got a Joes Woodworker vacuum pump, and a sliding door track off a commercial bldg.
Need a winch and vacuum pucks to be in bidness. The Lyme Disease makes me think this would be a good project.
Old Tue 01 March 2016, 17:01
I believe Gary Campbell, who is a member here, has a video of a DIY panel lift in operation...
Old Tue 01 March 2016, 18:42
islaww
Just call me: Gary C
UP of Michigan
Darren...
Sure do, but it doesn't have any good closups: https://www.youtube.com/watch?v=IsFt-CMsbvs
Old Tue 01 March 2016, 19:58
Yep, thats the one that got me noodlin Gary.
I'm wondering how a sub $200 Harbor Freight hoist would work here...
Old Tue 01 March 2016, 20:33
A DIY solution is here: How-to-make-a-vacuum-powered-plywood-lifter
Old Tue 01 March 2016, 21:13
Thanks Jack. Hopefully Pete benefits from my hijacking of his thread...
Old Wed 02 March 2016, 05:28
Kornerking
Big Falls, Mn
Hey, where did my thread go? Hehe.
No problem Darren.
That is very similar to what I am thinking. Main difference is I plan on a full 60 x60 vacuum surface so hopefully I will be able to unload and stack as well. It may be overkill.
Both ends of my machine will be tied up with dovetailing fixtures so the panel cutting will be in the middle. Everything up and over the sides.
Old Wed 02 March 2016, 08:27
Hmm, from my research, that may be difficult. It seems pucks are used to create a high vacuum per square inch of pod area. It may be difficult to achieve a strong vacuum over a whole sheet, especially with cutouts. That will reqquire huge CFMs.
Old Wed 02 March 2016, 19:47
tonymai
Just call me: tony mai
big falls mn
we got it all painted and started assembly this afternoon
Old Thu 03 March 2016, 14:25
Without pics, yada, yada....
Old Thu 03 March 2016, 19:28
Kornerking
Big Falls, Mn
Yada yada.
To busy building it to take pictures.
A few more bites of the elephant today.
Got all the rails on and level. Rollers on. Rides sweet and true.
Got the z slide together. Gas shock is in place. Tomorrow mount it and install motor.
Tony is getting the electronics installed in the box.
The thing that has amazed me to this point is that by taking small parts and building on it how it makes sense. When I first looked at the project I almost got overwhelmed.
Old Thu 03 March 2016, 21:14
Agreed. I felt the same way.
Back Doing Some Arcade Fun #19 - Smith's Falls, Ontario, Canada bradyaero MechMates already cutting 146 Tue 27 January 2015 10:41
'Clean' Vectors - free project plans for the woodworker Kobus_Joubert Golden Resources 6 Thu 13 August 2009 07:34
It's all Darren's fault!! - Big Falls, Mn Construction started, but not cutting yet 0 Wed 31 December 1969 19:00
