Old Sat 06 July 2013, 21:20
Example from my build
Y chain
Old Mon 08 July 2013, 17:45
litemover
Just call me: Chris
Auckland
New Zealand
Thanks Pete; Looks good! I'll order more cable chain to do it.
Old Thu 18 July 2013, 23:41
litemover
Just call me: Chris
Auckland
New Zealand
hey everyone,
I'm moving my table this weekend to it's shop. So looking forward to that as it has 3 phase electricity for the spindle which is nearly wired up.
I have one question, Ive just purchased a gas spring which said 150nm for my 4k spindle. It seems quite stiff, am mounting it now. If the spring is too stiff, will it damage the Z motor or anything?
Chris
Old Fri 19 July 2013, 00:32
You can not damage the electrics/magnetics of a stepper motor by having too much external load. It may skip steps and you get some rough noises, but the motor has no damage.
Old Fri 19 July 2013, 03:41
In my opinion its better to have a less power then too much power on a Z gas spring. Motor moves my Z even without gas spring so he has enough power, if you get too strong one it may in some cases loose steps when plunging, very difficult to notice sometimes
the declaration on it may be misleading, put 15kg on it and see will it slide in
Old Fri 19 July 2013, 15:18
When you weighed the assembly, did you order a spring to match it? It should move freely when assembled. Mine is within a pound and moves easily by hand when assembled but does not drift down. The spring on each of our assemblies is different based on the build. I have a 30 lb spring.
Old Sun 21 July 2013, 19:17
litemover
Just call me: Chris
Auckland
New Zealand
Painting and Priming.
Just finished moving the machine, painting it while it is apart. Man that was a heavy mother. I calculated the mass of it based on profiles and tube width and it is over 1100 Kilos! The two side frame pieces with main X long beams alone are 700 kilo! Smelled the clutch of my friend's 4runner big time last night Anyway, sorry it took a while to get back to you guys.
The spring won't go down on it's own just by itself. But when I put the assembly on top of the sprint and push down, it will go down with a wee bit of force. Not sure how much, maybe 5LBS off. I bought the spring from Ebay in China as that has been the easiest way for me to get reasonable stuff these days. Can't buy a mcmaster car one here unless I send it to the US first then have someone send it to me.
The whole assembly weighs about 30 LBS I guess. I could add weight to it to make it heavier until I can find a spring that would be better.
Last night after moving, I rolled one more coat of black guard on it to cure rust as I noticed a slight layer of rust developing from keeping it in the garage where it is moist from all the rain. I'm going to put one more layer of black guard on today for good measure, then re-prime/seal it with a 2k primer prior to painting with a 2k paint, so today is prep.
Old Sun 21 July 2013, 20:20
I would believe that you would want it to return up if anything but I may be wrong. I thought I read that somewhere.
Old Sun 21 July 2013, 20:30
Red_boards
Just call me: Red #91
You can try Schutties fasteners in Moorabbin, Melbourne (03) 9553 2032 for a custom shock (~$50 a few years ago). Helpful people. They may ship to NZ.
It takes some effort to move my Z down and it only returns up slowly after power is removed. Been fine for 2 years now.
Old Sun 21 July 2013, 22:06
Your gas spring sounds about as good as it is going to get, if it is only 5lbs off. They are not made very precisely and they do "settle" a bit (they get smoother, less friction). Realise that your stepper motor, when switched off, will probably take more than 5lbs to turn.
Old Mon 22 July 2013, 19:07
litemover
Just call me: Chris
Auckland
New Zealand
Yes, I think the shock should be ok then if that is the case. I could get a custom one here in NZ pressurized to whatever I needed, but it's $115 compared to the $20 incl shipping I paid for the shock outside the country. My rig weighs in at 28LBS and the shock is rated for 33, so hopefully I don't miss steps. Probably worrying for nothing.
Getting my 2k primer today, it should hopefully smooth out some of the surface texture. Going to shoot 1 coat of enamel primer over the blackguard, sand with 600 grit, then 1 coat of 2k primer, then paint and clear coat. Should be a smooth finish I hope.
Old Mon 22 July 2013, 19:42
That little bit of resistance from the gas shock is not going to cause any problems with steps especially with reduction.
Old Mon 05 August 2013, 04:50
litemover
Just call me: Chris
Auckland
New Zealand
Made some progress painting. 2k primer, 2k paint turned out nice. The guy at the paint store told me the wrong ratio to paint on my other colour, so half the table is painted but turned out looking bad. Have to get some more paint to fix it. Moral of the story, always look at the paint tech sheet prior to painting.
Finished soon!
Chris
Old Mon 05 August 2013, 06:56
I hate it when you listen to someone who should know what they are talking about and don't.
Glad it worked in the end.
Old Sat 31 August 2013, 21:35
litemover
Just call me: Chris
Auckland
New Zealand
Well, the machine is finished painted, and cutting nicely. Will post some photos shortly. Does anyone have a file for a waffle grid vacuum tabletop they can link me to? I remember seeing one somewhere but can't seem to find it again. Thanks!
Chris
Old Sat 31 August 2013, 22:33
Would sure like to see a few pix
Old Sun 01 September 2013, 04:06
litemover
Just call me: Chris
Auckland
New Zealand
The Machine cuts
Here are some pics, and I have a mov of it cutting that I will post later. The colours are Lemon Yellow, and carbon black metallic. You can see the metallic in the sun and in the lights. Looks sharp though next time I will avoid metallic paint a I had to paint the black twice!
screen capture tool
Old Sun 01 September 2013, 04:33
litemover
Just call me: Chris
Auckland
New Zealand
Here is the video of it cutting. Very nice cuts! Fast too! This was only about 4000 mm per min cutting.
https://vimeo.com/73555725
Old Sun 01 September 2013, 05:31
Nice wook....now the real reward starts....
enjoy
Old Sun 01 September 2013, 06:12
Chris that is awesome! Congrats!
Old Sun 01 September 2013, 06:32
Very nice.
I have much to do and learn.
Old Sun 01 September 2013, 08:01
Great pix. So awesome.
Old Sun 01 September 2013, 09:42
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
Nice and strong machine. Congratulations!
Old Sun 01 September 2013, 18:41
litemover
Just call me: Chris
Auckland
New Zealand
Thanks for al your support folks. Really appreciate it.
Chris
Old Mon 02 September 2013, 00:32
Andrew_standen
Just call me: Andrew #109
Dorset
Congratulations that looks good, cuts nice and clean.
Good luck
Old Mon 02 September 2013, 00:55
Mrayhursh
Just call me: Hurshy
Riverview, Florida
Wow
The color is awesome. consider pin striping?
Old Mon 02 September 2013, 02:12
litemover
Just call me: Chris
Auckland
New Zealand
Yes, I have thought about some pin stripes or graphix. Originally was going to give it an Ironman theme, lol. Working on a cool Mechmate logo decal. Should be interesting.
Old Fri 06 September 2013, 02:20
litemover
Just call me: Chris
Auckland
New Zealand
More Cutting.
Working on some 3d carving, it's such a cool thing to watch the machine cutting 3d. It's so precise and sharp. I managed to get my VFD running through Mach3 via PWM so quite happy with that. My spindle, a 4kw Chinese air cooled so can't go less than 8000 rpm, does that mean when I warm it up, I should start it at 8000 rpm or is that just for cutting?
Very happy with this machine. Was well worth it.
Old Fri 06 September 2013, 03:17
Your spindle can not go under 8000rpm? Do you mean it doesn't move at all?
Old Fri 06 September 2013, 04:07
litemover
Just call me: Chris
Auckland
New Zealand
No, it will go under, it's just that I was told not to cut that low because it won't air cool if I do.
Just started the build - Auckland, New Zealand wheelygood Construction started, but not cutting yet 24 Sat 03 April 2010 02:01
