Old Fri 15 May 2009, 09:41
guri
Just call me: guri
la plata
power supply 30VAC 300VA
Dear Gerald,
have you tested your
300VA toroidal power supply transformer:
Primary: 230 VAC single phase
Secondary A: 28 to 30 VAC, 9 Amp max (for the Gecko's driving half-coil PK296A2A-SG7.2 motors)
Secondary B: 8.5 to 9.0 VAC, 1 Amp max (for the PMDX-122 (and rectified for the limit switches if needs be)
(http://www.mechmate.com/forums/showt...+output&page=2)
You can recommend for same configuration?
I can buy locally in Argentina for U$77
thanks,
Old Fri 15 May 2009, 10:01
Yes, have tested and can recommend that specification.
Old Fri 15 May 2009, 10:44
guri
Just call me: guri
la plata
thank Gerald... I go by another part of my cnc project
Old Thu 18 June 2009, 16:13
guri
Just call me: guri
la plata
rectifiera and capacitor
Dear Gerald,
I have the 300VA toroidal power supply transformer
I working in the power supply
I have calculated the following capacitors and rectifiers:
for secondary A:
capacitor 22000UFX75V
rectifier bridge 25A 200V
For secondary B:
capacitor 10000UFX50V
rectifier bridge 1.5A 200V
I have the right way?
Old Thu 18 June 2009, 20:46
guri
For secondary A: 10000uF 100V
For secondary B: 2200uF 25V
would be enough
calculated per the thumb rule that 1 Amp = 1000uF of cap reqd! and voltage rating of Cap to be double of the rated DC voltage.
Larger capacitance's would not help much I think, but if you already have em - then you can use em.
RGDS
IRfan
Old Thu 18 June 2009, 22:02
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
Is a capacitor on the secondary 9VAC winding for the PMDX really necessary?
I hope not, because my pmdx is running without one.
Old Thu 18 June 2009, 23:13
Jeff - if you read guri's first post he talks about using the same power for limit switches - may be thats why he want to convert it to DC - and hence the caps
Old Thu 18 June 2009, 23:26
The capacitor on secondary A has two functions:
1. Smooth out the ripple of the Alternating Current
2. Keep a reserve of energy when the motors need to make a sudden move. (Also provides a place for the motors to dump energy when they have to stop suddenly)
Mariss of Geckodrive suggests this formula: C = (80,000 * I) / V which results in (a) fairly large capacitor/s. A lot of guys have gone smaller without any obvious ill effects. Guri, I think your choice is fine.
Jeff, a capacitor (and rectifier) on secondary B is only required if you want DC to power proximity switches. Guri, the proximity switches are a very nice steady load, and you don't need to use the formula for the motor capacitors. I agree with Irfan that 2200uF 25V should be enough.
Regarding the rectifiers, I always tend to use something rated much higher than needed. This is because they are inexpensive, and the higher ratings are bigger and easier to mount. Then they don't need fancy heat sinks either. The 25amp rectifier for the motor drives should be fine, but a 1.5 amp for the proximity switches sounds a little small to work with. How big is that 1.5amp, does it have a mounting screw hole, can you solder wires direct to it, etc.? (There is nothing wrong to use another 25Amp for the prox switches. . . . )
Old Fri 19 June 2009, 06:49
Guri,
I would not be worried about the 75V for the secondary A winding. The 75V cap will be fine, they always have a surge rating on top of the posted rating. Sometimes this is marked right on the can. A higher voltage cap as Irfan mentioned is fine if you have it but are harder to find. ( and bigger)
Old Fri 19 June 2009, 08:32
lumberjack_jeff
Montesano, WA
Thanks Guys, I misunderstood guri's post.
Whew!
Old Fri 19 June 2009, 10:54
guri
Just call me: guri
la plata
I can buy locally in Argentina the following items:
capacitor 22000UFX75V GIGA 65X120 21.6A .003E SIE u$35.53
capacitor 2200UFX25V RAD.105ºC 20% 13X25 RGT CH u$0,30
rectifier bridge 25A 200V VI=80V $2.43899
I can not find:
22000uf x 100V
only:
33000UFX100V GIGA 75X165 27A .016E SIE u$75
Thank very much for help me
Old Fri 19 June 2009, 11:11
Guri - chk the local scrapyard - I have so many 10000uF 100V caps from old Uninterrupted Power Supplies (UPS)
and have used tham on all my electronic projects.
Old Fri 19 June 2009, 11:26
guri
Just call me: guri
la plata
Toroidal Mounting
Surfing the web I have found thid pictures about toroidal trafo mounting:
I think the mounting epoxy may have less cooling
what do you think?
Old Fri 19 June 2009, 12:41
The 22000UFX75V capacitor will work perfectly.
I will never buy a capacitor secondhand - they can be old and damaged. They are actually fragile, oil-filled devices which can corrode/leak and make explosions.
Our 300VA transformers are running very cool - the mounting method will not make any difference to the cooling. The metal disk + screw method is very common and I havn't heard of any problems with it. I cannot see the benefit of epoxy for this application?
