Thread Tools |
Need some MM plan info before spending $ for the plans
Gentlemen: I am new to this site and I am hoping someone can give me some insight as to the MM plan specs for guide rail extrusion sizes for the 3 axis as well as linear guide tyspecs before I Layout the cash for the plans. I would like a little more info before spending the money. I am currently considering the CNCrouter parts kit.
I am a custom cabinet shop dealing with kitchens, bathrooms, entertainment centers and hoping to get into fireplace mantels. I currently use eCabinets software which is only useable for Thermwood CNC machines which are out of my price range. So I am going to need to deal with new software that will enable me to generate a cutting file as well as realistic renderings for customer presentations. Fusion 360 and Aspire are being considered and any thoughts/input is appreciated. Jr |
There's a lot of information in the base table section
The MechMate is a welded steel design using standard structural shapes, and in the base design, V wheels, not linear guides. The rail for the V wheels is either custom ground by you, or bolted on. There are linear guide versions that folks have built, but that is not covered in the plans. You will need to be comfortable with basic steel work, including cutting, welding, grinding, shimming; none of it is super difficult, but it isn't a bolting extrusions together kind of project. The benefit in the end is a heavy, stable device. |
You want to see a MechMate in action doing cabinets look up Kornerking.
As far as the guides, the V rails work great. Don't fall into the thinking that you MUST have linear rails because the high cost machines do. That is one reason they have a high cost. |
Check out Polyboard software. It is parametric and is able to generate dxf...
Milosh |
| Gettin a plan - Gresham, OR | lintechnical | Introduce yourself and start planning | 4 | Tue 14 March 2017 07:29 |
| Workin a Plan - Lapeer MI USA | Jasonmm92 | Introduce yourself and start planning | 29 | Wed 28 December 2011 16:26 |
| Working Out The Table Plan | dakmonf | Introduce yourself and start planning | 32 | Wed 30 June 2010 12:59 |
| Staring to plan my first build | erich | Introduce yourself and start planning | 3 | Fri 30 April 2010 07:10 |
| Plan Question | Tim655 | General - MM Build | 20 | Thu 25 March 2010 08:18 |
