Old Tue 09 August 2016, 07:27
silverdog
Just call me: Sergio #70
Rome
Italy
Z slide cutting errors
Hi,
My MechMate #70 have been heavily modified, transforming it from welded frame, to a bolted one.
I am happy with the results but a new problem occurred:
each sequential pass on thick board came "a little bigger" (a slight offset).
I cutted a 19mm MDF board in three 6.5mm pass, each pass is slightly bigger.
All of the sides have the same problem.
I suppose there is a little play on the v-bearings ( a thought I had writing this post :-) ) and the force on the mill push the cut on the outside ...
Any other ideas ?
Sergio
Old Tue 09 August 2016, 07:47
6mm tool? Have you tried cutting in the opposite direction? Or another finishing pass at full depth?
Tool flex, bearing play, mount flex are the ideas that come to mind.
Old Tue 09 August 2016, 13:35
silverdog
Rome
Italy
Thanks Brad ...
I checked the z axis and there was a little play due to the two upper v-bearing not properly tighted :-)
Old Wed 10 August 2016, 14:41
silverdog
Rome
Italy
.... but it was not the problem ...
My next check is to change the 6mm mill with a 8mm and see, then che software problems .....
Old Thu 11 August 2016, 12:26
silverdog
Rome
Italy
The 8mm mill cut perfectly ! (like never before) you can't see any sign of the multiple pass
So the problem was with the 6mm mill, I think. It wasn't mounted correctly on the chuck.
Old Thu 11 August 2016, 12:35
I've seen lots of flex with deep passes in 6mm and smaller tools. It always surprises me that they don't break.
Old Fri 12 August 2016, 09:12
ditto on what Brad said. I have a good deal of flex on the smaller dia bits when cutting. 5/16 (8mm) or larger seem to always yield better results for me.
Old Sat 20 August 2016, 09:52
silverdog
Rome
Italy
6mm one flute is my most used bit, I have used many times on much harder material than MDF and never had such an evident problems in 6 years.
The problem I had was that the mill was not properly mounted on the ER20 chuck, the same mill gaved no problem once properly mounted. It was my fault
Old Thu 27 April 2017, 23:05
IamDave
Just call me: Davey
Ball Ground, GA
I cut mainly Extira and I use the 2 flute 1/4 and 5/16. The 5/16 really pulls it out and makes a clean cut. Extira I a heavy dust.
Cutting errors - slop in motors? Rocky Mountain Teardrops Troubleshooting 49 Fri 29 May 2015 21:01
Inconsistant cutting errors. SOSx Troubleshooting 85 Mon 12 November 2012 04:49
Cutting out_of_round circles - loose V-rollers on Z-slide javeria Troubleshooting 22 Wed 17 June 2009 06:15
Stepper motor refuses to turn - Wiring & jumper errors Gato Richy Troubleshooting 31 Fri 01 May 2009 00:56
