Thread Tools |
Using a chain for a rack
Using a chain is a common means of moving a trolley along a rail. The chain is tack welded to an overhead I-beam and a sprocket that is inside the trolley engages the chain. As the sprocket is turned, either by power or manually, it traverses the chain in rack fashion. My question is; can a chain be used in place of a rack for the rack and pinion drive? Racks are very expensive.
In comparison to the rest of the build, I think the rack is one of the less expensive and more important parts.
It really isn't much off a savings to go with a chain, and your performance will suffer. |
| Cable Chain Not Laying Flat | Zouave | 60. Wiring & Cable Management | 17 | Sun 31 October 2021 17:13 |
| Cable chain ("E-chain") - sizes and sources | Gerald D | 60. Wiring & Cable Management | 73 | Tue 02 October 2012 14:59 |
| Updated to Rack and Pinion from Chain Drive #62 - Fort Wayne, IN USA | scot | MechMates already cutting | 99 | Sun 22 May 2011 13:11 |
| Alternatives to expensive cable chain | Kobus_Joubert | 60. Wiring & Cable Management | 7 | Wed 16 July 2008 07:21 |
| Cable chain - E-Chain sizes & sources | Evan Curtis | Archives | 33 | Sat 10 November 2007 12:27 |
