Old Sun 30 December 2012, 06:11
Cirinbei
Just call me: Cirinbei
Focsani
Romania
Counseling MM - Focsani, Romania
Good evening everyone I took a cnc project abandoned my son after several trials I decided to build a mechanical MM for the project using the electronic Gerard got me do not understand much my son bought some electronics my question is if I them lead a MM - 2 pcs stepper motors SLO-SYN-101 and 2 KML092F PACIFIC SCIENTIFIC 802D343728774 IMS IB 106 __ Breakout Board Plus and Parallel Port Relay Board (Campbell) 3:1 gear (16 48) do not know price I use this forum somewhere if I'm wrong I apologize in advance thanks
Old Sun 30 December 2012, 09:49
Hello Cirinbei-
I think that english is hard for you. I think you are planning to build a MechMate, and you would like to know if the motors and electronics you got from your son will work.
The motors are SLO-SYN KML092F-101s, which are listed as:
Slo-Syn KML092F-101 Nema 34 Stepper Motors
3/8"dia shaft output shaft. 200 steps/rev (1.8 degree step)
Torque: 770 oz/in (Bipolar)
Current: 6.5 amps
Voltage: 1.74 vdc
Inductance: 2.86 mH
Resistance: 0.268 ohms
The motor drivers are IMS IB106 . They look like they match the motors.
I can't understand or search up anything on the other items you have listed.
Nema 34 motors in that size range with 3:1 reductions will work for a MechMate.
Without more detailed information, we can't give you any more help.
The motors will work. I don't know if the drivers will - I think so.
Do the motors and drivers and other electronics work if you hook them up and test?
Old Sun 30 December 2012, 14:03
Cirinbei
Focsani
Romania
bradm thank my English is google translation does not know how to do I attach photos so I hope you can help me to manage his sometime I have a (#?) on this forum
Old Sun 30 December 2012, 14:17
Cirinbei
Focsani
Romania
Old Sun 30 December 2012, 14:28
Cirinbei
Focsani
Romania
bradm I think I managed to attach photo after the year end holidays and will have laser cut parts as it is very cold and can not work on the mechanics decided to study and build the electronics tomorrow I'll do a photo for source supply units
Old Sun 30 December 2012, 14:33
Cirinbei
Focsani
Romania
help me connect them to see if they are functional please
Old Tue 01 January 2013, 10:04
My bad... it seems that Step clock is simply STEP and CW/CCW is a DIRECTION input so connect them accordingly.
here is the link for user manual
http://motion.schneider-electric.com...manuals/ib.pdf
You drives are CW / CCW input, Clock Wise , Counter Clock Wise
that means they need different output than STEP / DIR from Mach3 , Peter Homan posted an schematic to convert the signals here
http://www.servo-systems.com/pdf/ib10x_091803.pdf
But looking at the manual for your drives it says that pin4 is Step Clock and 5 is direction, that would mean that you have a jumper somewhere to change this. If that is not the case then just use the schematic to convert step/dir to cw/ccw
Old Fri 04 January 2013, 03:19
fanefane
Just call me: Stefan #73
Baia Mare
Romania
Bine ai venit pe forum si anul care a inceput sa-ti aduca un CNC !
Old Sun 06 January 2013, 16:28
Cirinbei
Focsani
Romania
Va multumesc domnule Fane Mihalca am urmarit lucrarile dumneavoastra si MM si plasma ,super masini bine facute si foarte bine studiate
Old Mon 21 January 2013, 15:42
Cirinbei
Focsani
Romania
MM sorry google translation is made ​​in developed and created your door why vexta and Makita seems I am not made ​​in USA?
Old Thu 24 January 2013, 05:32
Claudiu
Just call me: Claus #43
Arad
Romania
Salut Cirinbei,
bafta cu proiectul tau.
Hello to the forum.
Have #43, now building plasma MM - Arad, Romania Claudiu Construction started, but not cutting yet 5 Sat 15 September 2012 09:22
hello from Romania smeagle Introduce yourself and start planning 5 Sun 16 January 2011 06:58
Greetings from Bucharest, Romania rolix Introduce yourself and start planning 6 Wed 29 December 2010 15:29
Hello, from Romania omumaro Introduce yourself and start planning 1 Sun 12 December 2010 09:57
Greetings from Romania Claudiu Introduce yourself and start planning 3 Fri 26 June 2009 21:43
