#601
Chop Chop!!
#602
Alright enough testing lets see some chips fly. From your vid it looks like you are on your way. Great job on the conversion.
#603
Kobus, Hennie says he wants you to turn that into a chopstick.
#604
Kobus,
I recently learned that turners will cut the corners off before they start to help round off the piece. It is a faster process done on a table saw and helps reduce machine time. |
#605
The rounding Gadget in V-Carve Pro from Aspire takes a square piece of wood and quickly make it round...I like watching BBB working.
Here is a short video showing that with Vectric V-Carve - Pro it is really easy to do spirals and fluting...Even I managed to do it first time around. The lathe is not fixed to the ground yet and also not levelled, but I could not wait to try it.. http://www.youtube.com/watch?v=Wmlx6Y8w0c8 |
#606
Breg Gat ! ek hou daarvan
#607
Kobus, you make the whole subject of "indexers" look so darn easy!
#608
KISS I am too stupid to re-invent the wheel.
I am not hugging and kissing, just keeping it simple |
#609
Nicely done Kobus! I definitely want an indexer!
#610
really nice, I want one to..
Made this for fun, just to see how it's looks in blue Last edited by mikefoged; Sun 17 January 2010 at 16:53.. Reason: 2 same pic? |
#611
I think you find the next 'Gear' Kobus. Impressive.
#612
Nice Mike I like the drawing. At the moment mine is bolted to the floor.
I have the following idea... Make a new shaft for that old lathe. This one a little longer than the original....16 mm up to the end. Fit the old 3 way pulley on the shaft and connect the electric motor again. Put my 120 tooth Module 1 gear at the end of this shaft after the pulley. When I make spirals etc, use the stepper to drive the machine. When I finish the piece (sanding or small steps that I did not get right with the CNC setup) run the electric motor. This will give me the SPEED to sand and polish the piece. Also thinking of buying a 100mm taper lock pulley that will fit on the end and bolt my module 1 ...120 tooth gear onto this pulley. This will save some money as the engineering shops are mad with the price to cut a taper into my module 1 ...120 tooth gear. |
#613
Kobus, have a look for "weld-on" taperlock hubs. That type works with a key in the shaft.
#614
Thank's Gerald. What is the best type ofsteel to get for a shaft....must be about 25mm then I will turn it off to 16mm on that side. Will mild steel bar work ?
#615
Mild steel will work. Normally I would suggest you get EN8 which is slightly more expensive. But, nobody will sell you such a small bit and certify the grade - you will have to go scrounging and find a piece of unmarked steel in a scrap bin. So you aren't going to really know if it is EN3, 6, 8 or 24. Doesn't matter, you have a big diameter now.
#616
Kobus, there is a company in Sebenza on the corner of Ingwe and Grader Rd that sells short pieces of EN grade steel. In Wadeville between Rossouw and Nagington there is a company that sells ground bar, which will be much less troublesome than mild steel.
#617
Why do I do it...Because I now CAN
Thank's Jan...Wadeville is close to my work.
I wanted to do this for a long long time. Now I did it. After bolting the lathe to the floor and setting up things to be level, I made my little piece. It is 3 flutes 150mm long. DSC01007.JPG I see I have a brand new heading...about time Last edited by Kobus_Joubert; Mon 18 January 2010 at 12:26.. |
#618
kobus very nice, see that is what indexer do .
I was thinking about when you bolt the indexer to the floor it is not flexing with the Mechmate, is this a problem. |
#619
Kobus,
Very nice, did you laminate the wood to get the interior hollow? I like it. |
#620
Hi Mike, I now find out that my table is not that solid. After using it for so long cutting X and Y, I did notice the table shake somewhat, but did not worry about it. Now with the indexer on the ground I can see the oscillations. As a temp. fix I wedged a piece of wood from the side to the wall. This weekend I plan to make some struts from the sides and bolt those to the floor. It was not causing problems, but I did not like the SHIVERS that old BBB showed....was worried he is getting old like me..
Heath, that is one solid piece of oak. I use a 6.35mm straight cutter and went in deeper and deeper. Set up V-carve pro to cut in 1.5mm steps up to 16.5mm. Then 0.8 mm deep cuts until I saw it cutting through....broke the first one when I tried to cut too deep too quickly. The twists are not that strong. At the end took a 12mm ballnose cutting a 3mm to finish the groove. Last edited by Kobus_Joubert; Mon 18 January 2010 at 12:53.. |
#621
Reminds me of the Legacy Wood Working Tool Demo! Looks great. If I remember correctly if you are able to move the tailstock up or down you can make tapered ornaments. I should go and check out their website before I start passing on bad info.
#622
Very nice Kobus!
You make things complicated for me. There are a thousand more ideas from the wife side after she looked at your post. |
#623
Kobus I see it is another thing that you can cross of your bucket list.Baie mooi
#624
Ground Bar Industries
42 Stanhope Road, Malvern East, Johannesburg Telephone: (011) 607-2000 |
#625
Baaie baaie mooi Oom
#626
The way Kobus is playing with his MM it won`t be long then he is going on retire right in front of BBB.
#627
Kobus, now you become my model... Please, please make a video with this job !
I didn't forget what I promise but Gmail don't allow sending exe files. I'll find a way to send you those files. Marius |
#628
Ok Marius, will do sometime.
Tonight decided to try the OTHER available gadgets in the V-Carve Pro program. Firstly...HI-TECH way of setting the Indexer on Zero... you must have noticed that extra wiring to proxies and limit switches and stop blocks are out for me. DSC01008.JPG Then did a 4 flute where I ramp in and out at the ends. DSC01010.JPG Then a single spiral LEFT and then a single spiral RIGHT DSC01011.JPG And finally. The words MECHMATE, KOBUS and ERWA on a cylinder. MAGIC........ DSC01016.JPG |
#629
gixi just rename the file to .txt after the file name and kobus only have to rename it to .exe when he receive the file. easy
#630
Kobus, enough already, that just looks like too much fun!
Similar Threads | ||||
#11 Has died a fiery death– Cape Town (S. Africa) | Alan_c | MechMates already cutting | 556 | Tue 10 August 2021 21:54 |
Tables of all kinds | Kobus_Joubert | The Show Room | 17 | Fri 04 May 2012 08:33 |
On to parts Ordering - Matthews NC USA | qroger | Construction started, but not cutting yet | 51 | Mon 11 October 2010 05:07 |
One system controlling two tables? | Mountaincraft | 701. Motor Drives | 4 | Fri 10 September 2010 18:27 |
Ordering parts: Marysville, CA-USA | MachineMonkey | Construction started, but not cutting yet | 7 | Fri 13 March 2009 18:45 |
