Old Fri 10 September 2010, 11:01
Mountaincraft
Just call me: Mark
Shingletown, Ca.
One system controlling two tables?
Is it possible or practical to use one computer, PSU and set of drivers/BOB to run two different tables (NOT simultaneously)
I'm thinking along the lines of a multipin switch or several relays (or even some sort of home made knife switch) that would switch between one set of motors and the other .....
Is this crazy? Even as a short term solution? Would sure cut down on costs...
Mark
Old Fri 10 September 2010, 13:37
Mark, it's probably not crazy if you use a series of connectors. Moving four motor connectors and say two sensor and switch connectors from one table to another should take less time than loading the material onto the table and fastening it down.
Old Fri 10 September 2010, 13:52
Mountaincraft
Just call me: Mark
Shingletown, Ca.
I'd be able to save separate profiles on the computer for each table, correct? One for the plasma table and another for the router table?
Mark
Old Fri 10 September 2010, 13:58
You certainly can with EMC2, I don't know for Mach3, but I'd be shocked if you couldn't.
Old Fri 10 September 2010, 18:27
Mark,
That is exactly how I set up our table and others in the past in Mach
MM - router.xml file
MM - plasma.xml file
MM - indexer.xml file
Make as many as you want for the setups you do most often.
Tables of all kinds Kobus_Joubert The Show Room 17 Fri 04 May 2012 08:33
Fish shaped trivets for hot dishes on dining tables sailfl The Show Room 5 Fri 17 April 2009 03:25
Runs out of steam? Machine freezes during cutting - controlling PC's performance liaoh75 Troubleshooting 11 Thu 23 October 2008 22:34
Comparison: MechMate 4'x8' System to the EZ-Router 4'x8' System dmoore Archives 0 Thu 22 May 2008 10:23
