Old Mon 05 May 2014, 11:12
Foam
Just call me: foam
Dallas
2nd mechmate and hot wire cutter
Getting ready to start a 2nd mech mate. It will be a 4x. Built my first a few years ago for a company I was working for. A lot of time spent head scratching but it turned out great. This one will be alot better and the build I hope will be faster. I'm shooting for a six week or less first cut. Im also going to build a hot wire foam cutter using the same side design as the router. I hope thats ok, Mike.
Old Mon 05 May 2014, 11:24
Well, I'd say welcome to the forum, but we are only a couple weeks from your third anniversary of joining. How about Welcome back instead?
How about some pics and documenting these builds?
We all learn from each other.
Old Mon 05 May 2014, 11:44
Foam
Just call me: foam
Dallas
I plan to doc this one better than the last. Was thinking of doing a YouTube series on each step. A first build can be a little intimidating, but it really is not to bad looking back. I know exactly what I want to do this time and can avoid those little go back three steps mistakes hopefully.
Old Mon 05 May 2014, 12:22
I agree completely.
I've said it before, documenting the build forces you to a higher build quality because you know there will be onlookers.
I hope to start build #2 soon, myself.
Old Tue 06 May 2014, 04:36
Welcome back !!! For those building , keep in mind that I supply most parts for the machine including electronics and the sale of the parts helps support this great resource !!
I am looking forward to seeing your ideas on using the platform for a foam cutter.
Question regarding Plasma cutter on MM darren salyer 50. Toolheads 5 Fri 07 March 2014 11:09
Mechmate Plasma Cutter - Lipik, Croatia Brain Construction started, but not cutting yet 101 Tue 09 October 2012 09:15
Getting cutter to cut at a 90 deg angle to the table hennie Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 8 Tue 08 May 2012 22:25
Which spoil board cutter to choose from ? Robert M General - MM Operating 20 Sun 21 August 2011 18:53
Plasma Cutter Ron Petersen 50. Toolheads 38 Wed 30 March 2011 13:10
