Old Mon 05 April 2010, 20:03
uirobot
Just call me: robotdigg
Shanghai
China
Send a message via MSN to uirobot Send a message via Yahoo to uirobot
About the heat. We have tested too much, if you motor generate heat much higher than 70 degree, we would say your motor is bad one or bad condition.
Our Stepper Motor Controller with aluminium heat sink enclosure and thermal grease and so on for heat dissipation, the controller itself generate little heat.
Old Mon 05 April 2010, 22:47
liaoh75
Just call me: David
Taibao
Taiwan
Uirobot, does that mean your stepper driver can take 60-70 degrees C day in and day out on the back of a NEMA 34 body stepper? Isn't that pretty close mil-spec thermal ratings? I know mil-spec rated PLCs have to be able to take 70 degrees for a set amount of time but not indefinite. My OM 7.2 geared 296 motor runs at about 50-60 degrees easily in the summer time. My Geckos in a well ventilated cabinet hums along at about 40-45 degrees when the ambient temperature is about 33-35 degrees C. I don't know of too many electronic goods being able to take that kind of punishment long term.
Old Mon 05 April 2010, 23:20
uirobot
Shanghai
China
I really appreciate your question. I am the Product Manager not Product Engineer. But I want to tell you that we tested our UIM24008 Stepper Motor Controller clockwise setting the current 8A and after we measured out the tempreature of our Controller is 68 degrees while the motor tempreature is higher. What I want to tell is that we design our products strictly according to our technical figures given out but for different application, we are glad to have your reports. Thanks!
Old Thu 08 April 2010, 23:31
uirobot
Shanghai
China
Stepper Motor Controllers User Manual are available in English.
I like this wonderful forum, I am a fishing website owner I wrote on my website that I'd think a forum to spare spams the best way is setting a area for ads. In my eye you and I will find some related ads are useful.
Sorry, a little far away. Our English website is coming soon, now the User Manual of our stepper motor controllers are available in English. If you wanna take a look, please write me letters to tiger@uirobot.com
Old Thu 08 April 2010, 23:44
uirobot
Shanghai
China
Originally Posted by bradm View Post
I think the key question is how to integrate these CAM or RS232 protocol drivers into Mach3 or EMC2.
Tiger, we normally use four motors on three axis. The X axis uses two motors. In some cases, five motors are used for four axis.
Can you tell us more about how these motors are interfaced to a (standard Windows) control computer, please?
Hello Bradm,
First thank you for your question. Our stepper motor controllers are integrally mounted onto motor through corresponding flanges. If your motor have rear shaft, a "L" type flange will be needed.
To control many motors at different Axis, you may adopt our CAN protocol stepper controller. A CAN/RS232 Converter is needed here. One Converter could at most connect to 112 motor at the same time and then be connected to your computer, you give out orders, we have Global Command so you can drive your motors synchronous. Also you can drive one by one.
UIrobot
Tiger Huang
tiger@uirobot.com
Old Thu 08 April 2010, 23:51
uirobot
Shanghai
China
There are a lot of factors that are hiding in the background. Most of us use the Geckodrive products, particularly the G203v, which has 2000 steps per rotation, automatic current reduction, LED indicator (yellow) that shows when the drive is pulling too much current, and fail-safe operation that protects the user from self-inflicted self-destruction.
What does this drive offer that the Geckodrive does not offer?
Richard,
Thank you for your feedback!
Our UIM 240 Series may do all the work Geckodrive can do.
UIM 241 with RS232 and UIM 242 with CAN will different from theirs. UIM 241 and UIM 242 Series are standalone, you don't need an extra controller to control driver. We can control at most 112 motors at the same time using UIM 242 Series and the CAN/RS232 Converter.
I am glad to send you our User Manual if you wanna know much more. Thanks again.
UIrobot
Tiger Huang
tiger@uirobot.com
Old Thu 08 April 2010, 23:53
Originally Posted by uirobot View Post
. . . I'd think a forum to spare spams the best way is setting a area for ads. In my eye you and I will find some related ads are useful. . . .
The limit is to have only one thread per advertiser. Your new thread has been joined to this one.
Old Thu 08 April 2010, 23:57
uirobot
Shanghai
China
Originally Posted by isladelobos View Post
and about electrical noise? and wire lenght?
RS232 100M and CAN protocol 10 killometers.
Old Fri 09 April 2010, 00:06
uirobot
Shanghai
China
That's fine.
Here I claim that our User Manual in English are available, welcome asking for a look. Our Stepper Motor Controllers are 14 non-condtional refundable and changeable.
Old Sun 11 April 2010, 08:58
liaoh75
Just call me: David
Taibao
Taiwan
Uribot, would you be willing to post a video of your drivers working (mounted on the back of the stepper) with nema34 steppers running under Mach3?
Old Sun 11 April 2010, 23:46
uirobot
Shanghai
China
I am sorry that we cann't run under Mach 3.
Old Mon 12 April 2010, 10:29
Don't you have Mach3 or is your drivers not capable ? Mach3 takes in standard G-code. I not understand.
Old Mon 12 April 2010, 12:09
Kobus, as suspected above, it appears that these drivers will not accept a simple step/direction signal. They can be controlled via RS-232 or CAN bus. Both of those are too slow to transfer the pulse train that Mach3 and/or EMC2 generate.
There's an outside chance that with serious software rework, someone could write a (software) driver for these that sent the higher order commands from the trajectory planner inside Mach3 or EMC2, but that would be a lot of work, and has not been demonstrated successfully in other attempts. The issue is that keeping the movements of multiple axis in precise synchronization while using a slow communications link is extremely difficult.
Old Mon 12 April 2010, 12:37
I am not so sure. I think he is shoothing himself in the foot.
From the data in previous post nr.14 this is what I see.
Old Mon 12 April 2010, 12:52
True, that would work, assuming you find a way to get the signals there.
Old Mon 12 April 2010, 13:15
No problem, leave the controller in your box and only extend the motor wires like we do in any case.
This thing does not have to be mounted ON the stepper, even if it has the facility.
Old Mon 12 April 2010, 14:28
normand blais
Just call me: Normand
montreal
they dont even need to be in the box
Old Mon 12 April 2010, 19:12
uirobot
Shanghai
China
I am sorry that I don't know Mach3.
Old Mon 12 April 2010, 19:17
uirobot
Shanghai
China
High speed RS232: 115200 bps
high efficient CAN (UI CAN): 1M bps
One full CAN message takes: ~100 micro seconds (tested)
total node number x: ~100 (designed for, not tested)
Old Tue 13 April 2010, 16:09
100 microseconds = 10,000 updates per second.
200 steps/rev stepper motor at 10 microsteps = 2,000 steps per revolution.
10,000 / 2,000 = 5 revolutions per second = 300 RPM on the stepper motor.
Assuming 20 tooth, 20 pitch gear on a MechMate = about 3.14 inches per revolution. Times 5 revolutions per second is 15.7 inches per second or 942 IPM.
That sounds good, until you factor in updates to 4 or more motors on that bus, and you're down to 235 IPM or less, and that's assuming perfect performance.
And that is direct drive, and we generally have either gearbox or belts in the range of 3.6 to 7.2 to 1. So cut that down to 32 to 65 IPM. That's very slow.
Even with a dedicated CAN bus for each motor, it's still only 128 to 256 IPM.
Somebody check my math, I've been mistake prone lately
Old Wed 14 April 2010, 00:00
uirobot
Shanghai
China
USER <<==High speed RS232==>>UIM250 Converting Controller <<== high efficient CAN (UI CAN) ==>>UIM242xx Motor Controller (Node 1) <<== high efficient CAN (UI CAN)==>> UIM242xx Motor Controller (Node 2) ...<<== high efficient CAN (UI CAN) ==>> UIM242xx Motor Controller (Node x) .
Old Wed 14 April 2010, 00:09
uirobot
Shanghai
China
Richards,
Our UIM 240 Parallel Model is a driver, UIM 241 Serial and UIM 242 CAN protocol are intellegient controller, no need extra control card or so. UIM 242 can control synchronous 112 motors at most, who can make it.
Old Wed 14 April 2010, 00:14
uirobot
Shanghai
China
I do see some advantages, by mount the driver on the motor, we will eliminate any potential noise within the control panel, just wire the DC power & smaller shielded signal wires from the bob to the motors.
Cheaper cable cost as we can use cat 5 instead of those expensive big 1mm2 shielded power cables... the power cable can be a 2 core 1.5mm2 normal cable....
Maybe we don't even need the cat5 for the signal to the motor...
Maybe we can build (smaller) dedicated power supply units & install them right next to each motor....
Yeah, Ken
You do not need shielded power cables and even the cat 5. Normal cable with do all the work. It can connect User Device by RS232 cable with DB9, DB15 or DB25
Old Mon 10 May 2010, 21:51
liaoh75
Just call me: David
Taibao
Taiwan
Do you have a model that will work with Mach3 and take step and direction pulses?
Old Mon 10 May 2010, 23:10
I think this one will do it at 4 Amp David
UIM24004B
1-9pcs 48USD
Old Mon 10 May 2010, 23:17
Look on this page
http://en.uirobot.com/robot-archive-a-357.html
Communication: 3-wire, Step, Direction, and Enable signals
DIR, SPD, CUR, STP, Microsteppers
UIM240XX Stepper Motor Controller
Old Fri 04 June 2010, 02:40
uirobot
Shanghai
China
UIM24302 Parallel Micro stepper motor controller
Product Feature:
Micro Size, 16mm*24mm*2.5mm
Embedded stepping pulse generator, adjustable frequency
ON/OFF, Reset, Direction 3-wire control
10-35V DC, 2A adjustable phase current, 16 microstepping
TTL Logic control
Old Fri 11 June 2010, 13:12
I found more info on the UIM24004 driver....the one that will take STEP and DIRECTION pulses.
http://www.slidesandballscrews.com/p...ish_%20_2_.pdf
In the documentation is states:
Low-Level pulse duraion should > 8 uS
Max Pulse frequency is 50 kHz
How does this compare to the Gecko ?
Old Sat 12 June 2010, 10:05
Kobus got his MM to run on UI Robot drives today.
Old Sat 12 June 2010, 14:39
The Geckodrive G203v requires a minimum High-Level pulse of 2uS. It has a Maximum Pulse Frequency of 333kHz.
SPECIFICATIONS:
Supply Voltage: 15 to 80 VDC
Phase Current: 0 to 7 Amps
Auto Current Reduction: 71% of set current, 1 second after last Step Pulse
Size: 2.5”W, 2.5”D, .85”H (63.5mm, 63.5mm, 21.5mm)
Mounting Pattern: 4 6-32 screws, 1.75” by 2.375” (44.5 mm, 60 mm)
Weight: 3.6 oz. (100 gm)
Quiescent Current: 20 Ma or less (drive disabled)
Short-circuit trip current: 10A, 3uS response time
Step Frequency: 0 to 333 kHz
Step Pulse “0” Time: 2uS min (Step on rising edge)
Temp: 0 to 70 C
Step Pulse “1” Time: 1 uS min
Humidity: 0 to 95 % (non-condensing)
Direction Setup: 200nS before step pulse rising edge
200nS hold after step pulse rising edge
Power Dissipation: 1 to 13 W (0 to 7 Amps)
Differences between G201, G202 and G203 stepper drives from Geckodrive Gerald_D 701. Motor Drives 59 Tue 03 April 2012 11:06
Used Intelligent Motion IM483 Stepper Motor Drives MillworkMike The Market Place 5 Mon 27 February 2012 20:36
Cheaper drives SLINK 701. Motor Drives 13 Wed 30 November 2011 02:33
WTB: Belt drives JamesJ The Market Place 1 Sat 27 August 2011 20:46
Question about stepper drives and motor direction DTGuitars 701. Motor Drives 13 Mon 18 October 2010 09:38
