Go Back   MechMate CNC Router Forum > Common Assemblies & Parts > Profiled (laser cut) & bent steel plate
Old Wed 30 April 2025, 01:59
igoldencnc
Just call me: Lee
jinan
China
Laser Cutting for Metal: A Beginner’s Guide
Laser cutting technology that uses a high-power laser beam guided by computer instructions to cut or engrave materials. It’s super accurate and precise and can create complex shapes and designs that would be nearly impossible to do by hand. You’ll find it commonly used in industries such as automotive, aerospace, electronics, medical, and construction.
You know, this guide is here to give you an in-depth understanding of CNC laser cutting, its applications, benefits, limitations, and trends. And trust me, this comprehensive knowledge can really open up new opportunities for both businesses and hobbyists.
Laser Cutting Machine for Metal
Fiber laser cutter is a CNC laser cutting system for metal, which is with high cutting quality, high cutting speed, high cutting precision and high cutting efficiency. It is suitable for most of of metal cutting and the fiber laser cutting machine is your good partner in metal processing. Equipped with different power (from 1,000W to 30,000w), it is used to cut metal materials with different thickness, such as stainless steel, carbon steel, electrical steel, galvanized steel, aluminum zinc plate, aluminum, aluminum alloy, titanium alloy, copper, brass, iron, etc.
Fiber-Laser-Metal-Cutting-Machine
What are the Main Stages of the CNC Laser Cutting Process?
Design and CAD/CAM Programming: It all starts with designing the shape or pattern you want using CAD software. When the design is done, it’s converted into machine-readable code with CAM software. This code has the instructions that will tell the CNC machine what to do during cutting.
Material Preparation: The material you want to cut, like metal sheets, wood, acrylic, or other stuff, is prepared and put on the CNC laser cutting machine’s work surface.
Machine Setup: The CNC machine is set up for the specific material and thickness. This means adjusting things like the focal length of the laser, choosing the right cutting parameters (like power, speed, and gas pressure for assist gases), and making sure the material is aligned correctly.
Laser Cutting: Once the setup is finished, the CNC machine starts cutting. The focused laser beam hits the material’s surface, heating it up until it melts or vaporizes. The high-energy laser then cuts through the material along the programmed path, following the CNC instructions.
Material Removal: As the laser beam moves, it melts or vaporizes the material. The melted or vaporized stuff is pushed out of the kerf (the cut path), leaving behind the shape or pattern you wanted.
Cooling and Solidification: The laser generates a lot of heat when cutting. So, cooling mechanisms like water or air jets are often used to stop the material from overheating and to help it solidify.
Quality Inspection: After cutting, the cut parts are checked for accuracy and quality. Any problems or differences from the intended design are looked at, and if needed, adjustments are made.
Post-Processing (Optional): Depending on what you’re making, the cut parts might need some extra steps like deburring, surface treatment, or assembly.
CNC Laser Cutting Programming
Stainless Steel Laser Cutting Machine
In CNC laser cutting, programming is really important. It makes sure the CNC machine does the tasks you want in the right order and way. There are two main programming languages used in this field: G-code and M-code.
What is G-code? G-code, also called preparatory code, is the most widely used numerical control (NC) programming language. It gives you precise control over things like the speed, location, and coordination of the CNC machine’s moving parts, like the laser head, axes, and tool feed. Each line of G-code has commands that tell the machine what to do and how to do it.
What is M-Code? M-code, or miscellaneous code, is another important NC programming language used with G-code. While G-code controls the position and speed of the machine, M-code controls other things like turning the laser on and off, changing the tool, or starting the coolant.
What are the Different Types of CNC Laser Cutting Machines?
There are different types of CNC laser cutting machines, and they’re different based on the kind of laser they use and the number of axes they have. Let’s take a closer look:
Carbon Dioxide (CO₂): CO₂ laser cutters are really common and versatile. They use a gas mixture with a lot of carbon dioxide and an electrical stimulation to make a powerful laser beam. These machines are great for cutting, engraving, and boring all kinds of materials, including most metals and non-metals.
Fiber: Fiber laser cutters use solid-state lasers with an optical fiber filled with rare-earth elements as the lasing medium. Fiber laser cutting is known for being efficient, precise, and having great beam quality. They’re especially good for cutting metals and are often used in industrial applications.
Neodymium-doped Yttrium Aluminum Garnet (Nd: YAG, or YAG): YAG laser cutters use a crystal as the lasing medium, doped with neodymium (Nd). These lasers are good for engraving and cutting metals and ceramics and can also be used for welding. The YAG laser can make high-power beams and can work in both pulsed and continuous modes.
Based on Axis: The axis of a CNC machine is the number of directions the cutting tool can move in. More axes mean you can make more complex shapes and cuts.
2-Axis CNC Laser Cutting: A 2-axis CNC laser cutter moves in a flat, 2D plane. It can move its laser head horizontally (X-axis) and vertically (Y-axis), and it’s best for cutting flat sheet materials like metal and wood.
3-Axis CNC Laser Cutting: Besides what a 2-axis machine can do, a 3-axis CNC laser cutter can also move its laser head up and down (Z-axis), so it can cut deeper. This is really useful for engraving.
4-Axis CNC Laser Cutting: A 4-axis CNC laser cutter can do all the movements of a 3-axis machine, and it can also rotate the workpiece around one axis, usually the X or Y-axis. This extra rotation lets you make more complex geometries and shapes.
5-Axis CNC Laser Cutting: 5-axis CNC laser cutters are even more flexible. They can rotate the workpiece around two different axes at the same time. This gives you a lot of control and precision when making multi-dimensional, intricate shapes.
6-Axis CNC Laser Cutting: The 6-axis CNC laser cutter is the most advanced. It has all the capabilities of a 5-axis machine plus another rotational axis. This means the machine can cut from almost any angle, making extremely complex and precise cuts.
What are some common applications of CNC laser cutting?
CNC laser cutting is used in a lot of different industries because it’s so precise and can shape all kinds of materials. Here are some of the sectors that often use this technology:
Automotive Industry: CNC laser cutting is really important in vehicle manufacturing. It’s used to shape sheet metal parts precisely, cut car body panels, and make small components with detailed designs.
Aerospace Industry: In the aerospace sector, precision is super important. CNC laser cutting machines are used to make parts with really small tolerances, and they’re great for cutting the exotic metals and composites that are often used in this industry.
Electronics Industry: From making circuit boards to creating parts for smartphones, CNC laser cutters are really useful tools in electronics production.
Medical Equipment Manufacturing: CNC laser cutters make it easier to produce surgical tools, medical devices, and orthopedic implants, where details and accuracy are really important.
Jewelry Industry: CNC laser cutting is used a lot in jewelry making for cutting and engraving. It can make really intricate designs with high precision.
Construction Sector: Big CNC laser cutting machines are used to cut structural components for buildings, bridges, and other construction projects.
sheet and tube laser cutting machine
Diffusion of domestic laser cutting machines and advantages of laser processing AccTekcncLaser The Market Place 0 Sun 29 January 2023 23:24
Tolerance of laser cutting sh.y1234 Profiled (laser cut) & bent steel plate 6 Mon 25 April 2011 11:21
Laser Cutting Parts lisawaa The Market Place 6 Tue 14 September 2010 12:07
Laser/Water cutting racks? PEU Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 2 Sat 21 March 2009 09:54
Laser cutting in various countries . . . . vadeem Archives 12 Thu 02 October 2008 07:02
Copyright ©2000 - 2025, Jelsoft Enterprises Ltd.
