Old Thu 11 July 2013, 11:32
ilmataat
Just call me: Ivo #120
Jõgeva
Estonia
Settings problem???
Hey for everybody.
I hope someone can help me.
I have problem whit mine cuting result. If i want to cut rectangle result is:
1. Starting conner:
http://www.mechmate.com/forums/attac...1&d=1373563161
2. Oposite side
For eny arc or circle dont have this kind problem, but if program starts the tool is not in correct deepth before x and y axis started moving.
I tested for diffrent feed rates but nothing chance.
It can't be in g-code. beacuse if i use mach3 surfacing wizard. there is same problem.
Old Thu 11 July 2013, 13:22
Second picture tells me you have a gear that is loose on the shaft.
Old Thu 11 July 2013, 13:36
ilmataat
Jõgeva
Estonia
No i checked this, gears are tightily on a shaft. And this is not possible beacuse this mistake exsist every time.
I don't understand why x and y axis starting move but z axis is not in right deep, tool arhives right deep't about 20 mm after starting point.
I think, maybe i have wrong settings in mach3
Old Thu 11 July 2013, 15:00
Ivo, check those gears again, very carefully. Gerald is very, very good at photo analysis, and your symptom is very common, and has fooled many people who eventually discovered that there really was a loose pinion. It is possible, and typical for this error to be highly repeatable - same every time.
Old Thu 11 July 2013, 15:08
Corner rounding also can mean you have among loose gear a small acceleration. CV tries to keep constant speed so it rounds the corner. Try Exact Stop in general config or get acc up.
Old Thu 11 July 2013, 22:20
ilmataat
Jõgeva
Estonia
You mean this, i have to change acceleration higher in motor turning options? not in general config? i don't see there eny oppurturnity to change acceleration.
Put How high this acceleration must be. i have 69.976 steps per, velosity 7002 mm/m, acceleration is 29.175 mm/s Is it to low?
Old Thu 11 July 2013, 23:23
You probably have two problems, mechanical and settings.
The bottom half of the bottom picture shows a "wobble" or a "bounce" and that is impossible to be settings or software. Typical when coming out of a corner and the direction of forces on the cutter have changed, making a gear to decide to vibrate loose and move to the other side of the freedom/backlash/play that it has. You can only find that play if you switch on the motors and turn the gear with heavy pliers.
Old Fri 12 July 2013, 01:21
Ivo... put velocity somewhere in the range from 500 - 800 for start 29 is incredibly low if you are using milimeters
Old Fri 12 July 2013, 10:10
ilmataat
Jõgeva
Estonia
Thanks for evrybody. Problem is solved.
Accleration speed was too low, like danilom say's.
Thank you
Old Fri 12 July 2013, 10:25
Show us some pictures of something you cut, we all enjoy seeing those pictures along those when something is wrong
Old Fri 12 July 2013, 18:44
Yeah, make an example of you.
Old Mon 15 July 2013, 22:05
ilmataat
Jõgeva
Estonia
Before: lleft pic(Acceleration speed is very low compared velocity speed)
http://www.mechmate.com/forums/attac...1&d=1373947253
After: Right pic(balanced acceleration speed whit velocity speed)
Typical settings for Mach motor tuning Kobus_Joubert CNC motion control software 19 Sun 15 May 2016 10:04
Mach 3 CV settings Greg J General - MM Operating 2 Wed 17 November 2010 14:49
limit-settings/pin's and port's kongblom 70. Control Systems 6 Fri 20 November 2009 09:39
Today's changes to the Forum settings.... Gerald D Test Area for this forum 8 Sat 26 May 2007 11:48
